I know this is not an old tractor, but why do I keep breaking the odd bolt, (12mm X by solid shank), that holds the PTO lever to tractor. Finally got some dry weather and this thing broke for the second time in the last 12 months, PTO does not work. Knowing all time, they close at noon, it broke at 1:00 PM. Three weeks behind cutting hay.
Is the bolt you're referring to parts key 3? if so are you replacing it with a JD bolt?
Yes, that's the bolt. It's 12 MM, threaded part, goes up to around 7/8 inch. It is a JD bolt but seems light weight.
