jd 4030 fel joystick
mobob
I am wanting to change my front end loader to joystick control, it's a cab tractor. I think, after talking to surplus center that they have everything I need. The only thing (I think) that I am not sure of is the control valve Item # 9-6702-F. Is this the control valve I need? I also question the joystick itself Item#9-6704-J,i see Northern tool has one that looks like a guy could bend for easier control? I know this joystick stuff has been beat to death.
Thanks for any help
Bob
Thanks Tx Jim. I will call them back and see what else they have. As you can tell I am clueless!! May be better just to have ma deere get it all!!! Ha
thanks again
I have that very joystick on my loader and it works great. Be sure you have a valve compatible with the joystick conversion. It sounds as though you do. Be sure to get the closed center plug for the valve. My tractor has a 25 gpm valve very similar to the one you listed. It should work very well for you. Mike
