I have my tractor apart. Radiator and thermostat are out. I did this because I was running it a couple weeks ago and I turned the rpm down and jumped off to move some stuff around for a few minutes and it stalled. When I went to start it, it didn't want to start. Waited a bit and it started. 10 mins later it did it again. I put it away. next week I took it out to move some stuff. I got it warmed up and was running it at PTO speed for 15 mins. Temperature gauge never showed hot. Looked normal. I put it away and when I shut it off it ran on for a second. I decided since I had not flushed the system since I got it, I would pull off the hood and see what is what. I bought a new belt, thermostat and gasket for thermostat. What I saw was:
Radiator fins are filled with dust and oil? sludge.
Top of motor with same sludge.
Hoses look half OK.
Antifreeze looks dark.
the belt was way loose with chunks missing
Opening the petcock on the radiator yielded about 2.5 gallons of coolant, but the radiator looked full before I started. This was with the thermostat out.
So far in my shopping cart at the Deere dealer I have:
all new hoses and clamps
gasket for under the thermostat housing
radiator cap
air filter
I have an aftermarket temp gauge on order to verify the Deere gauge.
I am wondering the best way to proceed with cleaning and verifying everything. I don't see any freeze plugs, but I may just be missing them. I want to somehow confirm I don't have junk in my water jacket and figure out why the temp gage didn't show high when I suspect it was. I don't want to damage the radiator with a bad cleaning plan. Any advice or suggestions would be appreciated. I do have a coolant heater so was thinking of plugging in a hose to that connection for flushing the block.
Hoses look half OK.
radiator cap
air filter
