John Deere unstyled G rear axle problems
Hello everyone,
I have a problem with my axle on my unstyled G, someone has Axle Retainer Felt welded to the axle, as where the wheel pushes that I now have ground away everything exactly how I can now decompose?
Simply peel off the outside?
As it is attached again, I think it was not welded?
Has everyone pictures?
Florian
Hello,
sorry for my very bad english, I am from Germany :cry: .
How I can remove the rear axle from my unstyled G?
To make new seals in it and a new dust shield.
A picture will help me, too.
Florian
Florian, wenn sie auf den hinterer seiten von den traktor stiehen. Ist der a grossen 0 rund deckle mitte in die achsen gehause. Mach den deckle weg und shau hinein. sie warden zwei grossen zahnrader siehen links und rechts. In die mitte von die raeder ist ein mutter. Schraubt den mutter ab, und den werden sie die achse ausziehen koennen. Pass auber bitte auf dass die groessen zahnrad nich rause kommit von der gehause.
hoffentlich hilft das. Mine Deutsch ist nich dass was ess frier war.
Florian if they stiehen on the rear side of the tractor. Is the a large round 0 deckle center in the axes housing. Take the deckle away and shau into it. they warden two large COGS Siehen left and right. In the middle of the raeder is a mother. Unscrews the mother, and they will come out the axle can. Auber please pass on the sizes gear nich Rause kommit of the housing.
I hope this helps. Mine is German nich that what was freezing ess
(quoted from post at 14:14:20 04/22/15) Florian if they stiehen on the rear side of the tractor. Is the a large round 0 deckle center in the axes housing. Take the deckle away and shau into it. they warden two large COGS Siehen left and right. In the middle of the raeder is a mother. Unscrews the mother, and they will come out the axle can. Auber please pass on the sizes gear nich Rause kommit of the housing.
Translator really doesn't work well does it. LOL
Hello again,
is the rear axle cast iron, or normal iron?
Then my rear axle has no in German we say (Anschlag) to the outside.
Florian
