Aussie Ken
My friend checked the standby pressure, which was at 1800 - moved it to 2300 psi - changed hyd filter and cleaned screen which was dirty - the rockshaft still chatters a little bit -- BUT -- some one added a loader to tractor and just hooked the hyd feed and return to the SCV - as far as I know this will not work on a 2120 - once they operated the loader and then the rockshaft, the rockshft returns to chattering terribly - I have sent him pictures from the 145 and 175 loader manuals showing the lines feeding from behind the priority valve and returning to the filter canister. - Has anyone got one of these tractors with a loader that could take a picture of the connections for my friend?
The tractor also has a two stage clutch, which I have read needs to be locked out when operating a loader due to starvation of pump?
Thanks
Ken
Thanks
Ken
