Moondoggie
When I would shut down the B, there would be a banging noise coming from the crankcase area. Suggestions on this site some time ago said the flywheel was loose or out of adjustment. Sure enough, it was a bit loose on the crank shaft. Loosened it up and tightened it back down, but noticed that it is a bit out of plumb(?) when it revolves, to about plus or minus an 1/8 inch.
Shouldn't it be square to the crankshaft to prevent an increase in wobbling when it runs? I'm going to loosen it again and 'square' it with a dial, but wonder if there would be any other suggestions?
Thanks for your help!
