Hello everyone. I have a 1963 2020 with a front end loader on it. It's has a gas motor but it's been a faithful tractor to me for the last 15 years. Living way back in the boonys like I do the tractor gets used for a little bit of everything especially the loader to help lift and move things around since there's no one around to help. The only trouble I've ever had with the tractor is the hyd. hoses popping on the loader and that's only because they were the original hose until I finally wised up and replaced them all. But now I have a problem that I can't fix. The rear rims have been getting rough for a while until 1 of them has actually broke from being so rusty it's nothing there to fix. And to make it even worse they are power adjust wheels that I keep adjusted out as wide as possible to make the tractor a little more stable when lifting up things higher than I really should. Can anyone suggest where I can buy another rim or if a tractor of a different color would work ? The tire size on the tractor now is 13.9x36 and they got plenty of tread on them but I'd buy a rim or rim and tire if that's the only way I can buy one. So can anyone tell me where to buy another rim and do I have to go back with a power adjust wheel or can I buy a standard rim without changing the center hub? Thanks for your time and help.
