I just wanted to put this out in case any one here is looking for any of these used items pretty cheap. Just let me know. I can't recall off the top of my head all that they sent with me in the box so if you are after something particular just message me, I may have it. I don't really have a use for the stuff any more and if I can't find someone to buy the stuff it will likely sit in the box in the shed and rot which is a huge waste. If I do not hear from any one I am considering posting some of it on e bay briefly.
[email protected] for any questions or interest.
5 Piston/sleeve matched and numbered sets
1 Camshaft, was told it was still within factory specs, I had it replaced just because we were inside doing everything else.
1 engine oil pump, pressure was good
Clutch plate (not the button one)
My 66 4020D (~6500 hours on tractor) just had a complete out of frame engine over haul (#2 piston pin seized destroying that sleeve/piston, nothing else is damaged to my knowledge) a month or so ago. It ran good, compression tests showed balanced pressures) and was 100% reliable. The clutch was replaced while it was split so I have the old clutch hardware also.
