530 transmission problem
Buster
Working on my dads 530. Shifted from 4th gear over to 6th and it jumped out of the high low socket. Pulled the top off and for the life of me, I can't get it to go back together. Can someone out there tell me how the shifters need to be lined up for this to go back together????
The hi lo fork is the front most shifter. Release the lock and shift it ot high or low. Put the end of the shift lever in the slot in the shift forks of which ever way you pusher the range shifter.
Thanks ET. Worked on it tonight and got everything lined up and it went right together. Thanks Again for your advise
