I'm working on a GT275 lawn mower with a Kawasaki engine, for my neighbour. I don't have a service manual and neither does he, so I'm hoping a YT member may be able to help.
He brought it to me because it suddenly quit running. I discovered a broken intake valve spring. Easy fix. However, in the process of checking other things, I do not have any spark and the starter will not spin using the key. It will if I bypass the key, but I can't seem to find the combination that allows me to hot-wire the ignition. I'm think'n there may be a safety neutral switch involved. The machine is a hydro-static drive which is activated by a rocker style foot pedal. Push on the front of the pedal to go forward and push on the back to go backward. It seems to have a center position, but fiddling with it in the center position didn't help.
Anybody have a GT275 that might be able to shed a little light on the subject?
I would ask the owner, but after he brought the machine to me the rascal took off for a couple months.
Dave.
Dave.
