Hello All,
I have a 1968 Deere 4020 - Syncro. The other day, it suddenly lost all hydraulics. It has no brakes, steering, 3-point, SCV....nothing.
I immediately suspected the transmission pump, as I just recently replaced the main hyd pump. I removed the rockshaft housing, and re-sealed all the connections between the tubes and the transmission pump. The gears in the trans pump looked good. I cleaned the lower screen, which had barely any material in it - nothing that would restrict flow. I also re-sealed the bypass valve, on the left of the transmission near the filter. Naturally - I replaced the filter at this time, too.
I installed a manual de-stroke valve for the stroke control valve on the hyd pump.
I fired it up last night after doing all this and still no hydraulics. I tried de-stroking the pump with the manual de-stroke valve and still nothing. I have a gauge plugged into a rear SCV and I have no sign of any pressure at all.
I'm kind of at a loss of where to go next and I'm hoping for some advice from all you experts here. Thanks so much!
Mark P.
Mark P.
