1950 B Powr-Trol
pg. 110 of parts catalog PC-330 shows key# 17 (pawl) This is leaking oil out at a decent rate for some reason. I don't see where it takes an o-ring or anything in the parts catalog. Don't know why it's leaking either. Please advise! Thanks in advance!
If you remove the plugs those pins hold in there are 2 O-rings inside the housing for each plug. So a total of 4 O-rings. The one is up in there a ways.
