I've got a Deere 2440 with a Roosa Master JDB pump. The throttle shaft bushings or seals appear to be leaking. The engine runs perfect...it just drips fuel down the side of the engine. MOST of the problem is when you shut the tractor down. Whatever fuel is left in the pump above the level of the shaft leaks out.
I'm not losing sleep over it but I never could stand leaks of any kind. I've left a pan under the 2440 long enough.
Can anyone point me to the kit to repair this? And, more importantly, how big a deal is this...do I have to line up the timing marks, remove the pump, and tear it down or is the throttle shaft fix relatively minor.
I don't really want to tear apart a pump that is working fine...I'm thinking that will lead to about the same kind of regret one gets from "marrying in haste".
Thanks.
Thanks.
