3020-Adjusting Oil Pressure
When I remove the "cap", do I increase oil pressure by turning "in" or "out"? Any other info I need to know to do this? Thanks, kelly
Loosen the jam nut and turn it "in" a little at a time, you should screw a gauge into the sender port and see what is happening as you go...
