2950 loose part?
I'm hoping somebody has seen something similar. My brother's 2950, quad range, 1000/540 Pto, has one complaint, leaking load control shaft seals. When he drained oil to start work the surprise was one ball, like from a bearing, and metal flakes. We found the source of the flakes, used to be a thrust washer in the PTO final drive. The amount of flakes and material in the filters look like that is all that was chewed up. But the ball with no marks, and diameter 0.372 inches, we can't find in manual or part listings. (so far). Spreading everything across the shop floor to check is almost as painful as waiting for it to go belly up hooked to the no-till. Our thanks for any help or insight you can give on this.
Quad range trans was not an option for a 2950. Only balls I can think of are on the trans shift rail detents & pto lever detents which are 5/16 or .312 inches.
When I left the home farm the newest tractor was the 3010 utility diesel, been a couple of weeks, so if I'm wrong I want to know where I went off track. I'm using Catalog 4189-2950 25JUL14. Am I in the correct catalog at least?
