18.4 x 30 tires will tubeless tires work with tubes ??
I have a set of Goodyear dura torque radial tubeless tires I want to install on new rims from miller tire. The only thing I am concerned about is if the tubeless tire will go on the rims and can I use tubes like normal with these tires on the original style rims for a 630 standard?
Thanks
Jdtractorman123
It will work fine, just use a radial tube,the extra flex of a radial tire will cause a bias tube to fail
