Just bought a 1950 model John Deere M. The big hub caps on the front are missing, is that all that protects the bearings or should there be a smaller dust cap?
Another thing is that someone put an alternator on the tractor and it's not a 1 wire, uses the built in regulator. the only way to shut the tractor off is to lower the throttle all the way til the engine stops. then I have to take off a battery cable since there is not a switch. What's the best way to fix this? I'm thinking maybe buy a new switch for the dash and follow the wiring diagram to re-wire the whole tractor but dont know how to work in this alternator. Any suggestions would be appreciated. Thanks
