I've got a 2840 with just under 7000 hours that has no low end power. I bought it last fall and even then it didn't seem to have the power it should. When the engine is cold I can open the throttle wide open and the engine gains no rpms. Even after the engine is warm if I'm picking up a bale with the loader and go to pull forward it sometimes just powers out and dies. Last week I was grinding up a bale of hay with it at pto speed and it all of a sudden started losing rpms and smoking (black) more than normal under load. I've blown out both air filters and have new ones ordered as well as a new fuel lift pump. The fuel filter is new and was bled correctly. Should I crack each injector or does this sound like a weak injector pump?? Any ideas??
