I got a 5020 that has not ran in 22 years. Always park outside.
The engine turns over withe the starter. I have just made a couple turn with it with a weak battery to not damage anything.
I would like to remove the injectors, test them, drain crankcase and put new oil, pour a few drop of oilin each cylinders and then turn engine with the starter until I got good oil pressure.
Of course I will change oil and fuel filters, fuel supply pump, and plug in a 2 gallons diesel tank to derivate from the fuel tnak which smells very bad.
Do you think that this should work? Am I doing too much preparing and I should just drag it and see what's happen?
What would you do.
Thanks,
Fdt
What would you do.
Thanks,
Fdt
