msteinblock
Brought home a 29D yesterday, now the learning curve starts. Coming from an H I have a little to learn here. Paraded in 1988 then parked, everything is loose. It looks like it did not have a hard life, everything is pretty tight on it other than the front steering. I think all that needs is a couple washers to shim out the shaft. Anyway, first thing is to see if I can get some life out of it. What plugs are recommended? Tried to test spark and got nothing, however when I watched some youtube videos I noticed them reaching under the hood toward the mag to turn something on? I need to look closer, is there a switch under there? Other than that, just need to start with the usuals...fluids, filter, etc. Also got a set of steel wheels for it. Would love to put it on steel and pull a plow around...trailering is becomes an issue at that point. How do you handle trailering steel wheeled tractors?
BTW - I was a *little* surprised when unloading to find D's have no brakes!?!?!
