3010 Relief Valve Housing
2510Paul
I need to remove the Relief Valve Housing(53)on a 3010 to replace the 3 packing rings(54). Do I need to drain the sump? The manual does not mention it. Or, will the check valve after the rear oil pump keep me isolated? I don't think so but I thought I would post.
Thanks. Paul
Trying to upload a parts break down. Paul
This is located between the transmission oil filter and the sump screen plug on a synchro. Let me know if a picture is needed. Paul
