47 Loader Lift Cylinder Leak
dpoc
I have a John Deere 1020 with a John Deere 47 front end loader. One of the lift cylinder appears to be leaking out of the rod end of the cylinder barrel. Has anyine else have this happen before? Where would the oil be coming from? How difficult of a repair would it be to fix the issue?
Thanks for your help!
I'll guess parts key 12 is leaking
Remove outer snap ring,bump guide(parts key 12 into barrel to reveal 2nd snap ring then remove 2nd snap ring,pull rod & guide out of barrel to replace packings/seal
