Going to be setting the governor on the B soon. I have the cam and crank gears timed correctly.
Next is to have the cam timing dot up at 12:00 and the governor gear timing dot at 6:00, in line with each other, correct? Does it matter if the governor timing dot is at 12:00?
Then the flange for the mag should be horizontal. Then making sure the mag timing correctly.
Just what to make sure I am thinking about the is correctly.
