I know that you need to time the oil pump so that the Dist. will line up correctly on the 420 engine. My question is can the oil pump be put in 180 degrees out and allow the dist to be installed the same 180 degrees out and run just fine?
I have noticed that on my 420 the plug wires seem to turned 180 degrees from all the ones I have seen.
It seems to me that it should work and it does crank and run just fine I am just curious if anyone has seen this before and will it cause problems.
