R wiring diagram needed
Looking for wiring diagram for 1954 R serial #21330 - the generator has the cut out relay which works, there is one wire installed that runs from the cut out relay to the amp meter, but the tachometer wire had been removed as well as another wire where should these be installed?
Thanks
Heres a diagram
John T
