johndeeregreen
I pulled the right side axle housing off a jd 4440 powershift, the diff bearing does look a little bad. The race does show some spalling, not much, but some.
So looks like im replacing that bearing.
I'm a newbie to alot if this,
I need to check how much the diff moves and get the correct shims.
I dont need to check blacklash do i?
What's the best way to remove old bearing? I dont have a puller small enough.
