fixerupper
Finally got the wallflower out of the corner of the shop! This is the last of the winter projects! Yaaay! It's been in there since late last September when the sliding PTO drive gear wore through the first reduction cover because the bearing behind it slid out of the main case. The two bolt cast piece that holds the bearing in place broke allowing the bearing to work out. It broke because yours truly was in a hurry and crunched the PTO in gear years ago, putting a shock on the bevel gears, forcing them apart and creating more end play force than the bearing holder could stand. It took this long to finally do the fatal damage to the first reduction cover. Bevel gears are fine and smooth and all bearings are OK so I didn't need to dig deep into the bowels of the tranny to replace anything. This is the first time the PTO Has been quiet since I don't remember when. I did a few other things like crankshaft seals, new gasket between transmission and rear end rebuilt the shift forks and a few electrical odds and ends. Next winter the back end comes off for new axle seals and while I'm there new PTO Clutch and seals. Eventually it will be back in the shape it was in when dad bought it new.
