Wildride47
I am trying to make a systematic effort to improve the loader performance on my '61 2010 row crop utility. The loader is a JD 46 and has loads of strength to lift the front end but the lift cylinders don't want to lift a bucket of snow. I'm thinking there is an intern seal leaking. That being said I have tested the break away connectors for pump pressure and will do the same for the other points. I had 1200 psi at the break away connectors and power steering works great. I will check the loader lines next
My questios, what should I see for good pressure at the loader? And could the control valves be impacting the performance of the lift cylinders and still allow the bucket to be a strong performer.
