onefarmer
- Location
- 6735 S Lowell Rd, St Johns, Mi 48879
Having an issue with my 2550 w/sgb. Last summer the clutch was starting to drag and not want to fully release. It has had trouble with the slave cyl leaking so I was blaming it and the master. After replacing both the clutch still wouldn't release. I got to looking and it appears the slave does push on the clutch lever but not enough for it to disengage. The lever itself looks like it's all the way forward like the clutch should be disengaged.
Would this be the clutch facings came apart and wedged up between the flywheel and pressure plate? I suppose I need to do a split?
