Got a John Deere 1020 gas. The brakes worked fine and then it sat over winter and the pedals got stiff. When you pushed down on the brake peddles they didnt go very far down, the brakes still worked but the peddles had very little play in them. When you let off the brakes the tractor would move in low gears but would not roll freely. The two bolts were taken off the bottom near the plungers and some fluid came out and the brakes went to working fine. A few days later the same thing happened but this time by the time I got the wrench to drain the box by the plunges the brakes worked again. Any idea what is going on
Thanks
Thanks
