rincon_rider
New User
I apologize because I have asked this before but finally maybe able to get to it. My 4010 has had a steering issue since I've had it. Start tractor and wheels turn all the way left. Try to turn right the wheel won't turn but if you keep pressure on it the tires slowly turn right. After you get it all the wAy right the tractor will turn left and right properly. After like 30 seconds the steering wheel won't turn right again. But keep pressure on the wheel to the right the tires will go right then work decent again until it isn't steered for a few seconds. The hydraulics work properly so it couldn't be plugged screen or filter right??? Gotta be steering valve under the dash??? Not sure if I fix it or sell it or what to do. I hear getting steering valve out is a bi@ch and then have to test flow the pump??? It's not safe to drive on the road like this so here I am again asking for input. Thanks!!
