Unlead gasoline
Not at all, in later years lead was an additive(yes, that's correct and we got pay later for its removal) . In my area, the 91 octane esso crap is what regular was 20 years ago....at least no ethanol in it so far.
(quoted from post at 22:16:54 03/12/15) I have a 1939 John Deere B. I am wondering if using
unleaded gasoline will harm the engine.
There never was lead in diesel, distillant, kerosene, propane or natural gas. All those engines got along just fine without lead.
Excellent point! I've seen several people worry incessantly about unleaded gas burning the valves, eroding gaskets, and causing rough running, but these low compression / low RPM / heavily built engines would run on apple cider if you let it ferment long enough. haha
Back in the day, the lead was supposed to sort of cushion the valve seats. As diesel and LP gas became more common, so did hardened seats. Odds are somewhere in the past 75 years, your B got hardened seats- and no need to worry about lead.
Even if it didn't, odd are you are not going to run it enough to make a difference.
Just my .02 but I never leave any gas in any of my antique tractors. I use only ethanol free gas and make sure that I run them all dry then empty the bowl if possible whenever I run them. It's worked well for me for years now.
