Wedges for 9 bolt dual hubs
larryanderson
Have had a few sets of JD factory 9 bolt wedge style hubs.There must be more than one style as the wedges wont interchange and are hard to find.Need 3 3/8 have 3/1/8.They are supposed to be stamped on end but these are not.Any ideas/Tx Jim should be able to get me some numbers Thank You!
What is the hub number?
Larry, many times the wedges are the same as the same age cast wheel. However, be aware that earlier hubs have a different taper than later hubs. The wheel castings were like this as well. Mike
Larry : Look at the casting # on hub [not wedges],There are 2 dif. casting of 9 bolt hubs ; Early design , # R28490 , will [with correct wedges] fit 3 3/8 axles & down, Later design #R57969 will fit 3 3/8 axle & up... Wedges For the 3 3/8 axles are dif. for each dif. age of 9 bolt hub...
