Hey guys I ordered elect ingition from yesterday's tractor and flame thrower coil right wires will get dist cap and rotor from napta My ? Is on the resistor I believe mine is located in my key switch how do I do away wit that resistor that's on switch I no I take one wire with the the new set to the - side of new coil do I take the other wire to the + side of coil iam a little confused on that resistor in the switch do I need to do away with it I don't want to mess up new system If it helps the tractor I 1965 Jhon Deere 1010 powering RU I did not see any other resistor on tractor except on on key switch Thanks for all the help
