DLTX 81 on 630
jkmdg
New User
My next winter tractor project is to rebuild my carb on my 630. Took it off to figure out which type of carb it was, and discovered that it was a DLTX 81. The literature I have read is that number of carb was more for a 60, and that a DLTX 106 was for a 630. Tractor has been in the family since bought new, and grandpa can't recall ever replacing the entire carb on the tractor.
Before I buy a rebuild kit, just want to make sure there aren't any issues with running a 81 versus a 106 on a 630?
The power jets are all the same, the nozzles are all the same,throttle discs are all the same. I am not seeing any parts difference between the 81 (60 ) and the 94 or 106. The 81/94/106 (60/620/630 gas ) are the same as far as parts go. There may have been a slight difference in internal passageway size and/or idle port size and number.So as far as ordering parts it won't make any difference. Apparently there are no problems with using it if it has been on there all these years without problems.
