4430 3 point
mobob
I am looking at a 1977 4430 to buy. everything appears to be sound except the 3 point and it will not raise. We hooked up a cylinder to the hydraulic couplers and they work, I know that is really not a pressure test, but all I have. Is it possible that this could turn into some major repair or just adjustments? Also anything else I need to check? Quad stays in gear, steering is good as is the breaks.
thanks
Bob
I think 3 pt not raising will be a 3 pt linkage problem. Where is the L/D lever setting that's by your right leg when sitting in the seat? If it's not in minimum setting put it in minimum.
Tx Jim I did not look. Tomorrow when I go back I will look. That sounds simple enough for me to miss
Thanks
Bob
Also be sure nut(parts key 44) is tight in rockshaft housing.
