sway stabilizers for a 430
I used the two piece flat strap bar from a Ford/Ferguson. Ran it from the rear left load link to the right trunnion - had to drill new holes. This on a 320U.
Makes the drawbar/3 pt tool swing not at all.
That's what I was thinking about doing. Only question was when it came to installing a implement you need to be able to move the arms ?? Any pictures?
(quoted from post at 15:51:25 02/24/15) That's what I was thinking about doing. Only question was when it came to installing a implement you need to be able to move the arms ?? Any pictures?
The rigid arms are the last piece installed. Mount the implement first, center it then install the sway links.
Adrian
depends upn the model of 430, ie W, U, s. On my 430 U i put short pins on the inside of the drawbar supports and hook sway bars to them, one on each side. they are easily removed held on by a snap pin. I use one side plain steel, bent to fit and other side is adjustable like I found at farm store. Works good, I have a 320 U that has regular 3 pint pins pointing in and I use the same setup on it. JD made a kind of funky scissors type stabelizer for those tractors that slid over the drawbar. My uncle had one of those but it was a pain to use
im still working on r&d and test fits. I have some chains and turnbuckles, thinking about taking them from the pin on the implement to a bracket ill weld onto the drawbar assy on the same plane as the pivot pins on the tractor.
