720 diesel idleing
franknpdl
trying to get a steady idle on my 720 diesel when I try to adjust the idle speed, when I pull down on the throttle lever I can get it down to 700 rpm. But when I let go it the engine revs up to around 900 rpm and back down by it self. What could be the problem causing that?
Thanks for any help anyone can give,
franknpdl
I found the issue it was one of the governor weights the pin was gone and the weight was lying on the bottom of the governor housing. Thanks for all of the help again.
franknpdl
