Powr-trol Pump Driveshaft Washer (JD-70)
Does anybody know know which way the power-trol pump driveshaft washer goes on the driveshaft? The center hole has a tapered side and a flat side. I dropped the washer and did not see which end was which. The part number is C951R. Thanks.
This is how SM-2022 hyd. service manual explains installation....
You may need to magnify..
