JD 1520 loader plumbing question
PH
Where do I tap into the high pressure line for a loader valve. I
believe that valve is under the right foot board. Does Deere
make a tee fitting to tap in? Anyone have any pictures? I know
the return goes back to a ported filter cover. Thanks
You're correct one needs to tee into the rear of the pressure control valve.
Parts key 21 AW16707
parts key 13 C19280
parts key 6 C14618
