dieselfume
Yep, my 4630 is at it again. Aside from needing a new IP, I've noticed that the RH brake has lost alot of it's grab and must be pushed much harder to lock the wheel then it's LH counterpart. I also get a little growl from it once in awhile. Pulled trans/hyd filters today, the front filter gave me some very small flakes that looked maybe like steel or bronze in color. Figure it's got to be the brake lining.
So, With tires that have 3 drums of chloride in them, cast centers, and a 300+ lb wheel weights, I think I'm going to let the local guys handle this one. They tell me they'll leave the wheels on, chain it to the mast of the forklift and pull the assembly off together. 2 hours per side.
Does this sound about right? What should I be looking for in parts? Anything extra I'm going to need since I have one brake that's already metal on metal?
Should I buy Deere stuff or is A&I ok? (heard Deere bought them out?).
Anything in the trans that should be looked at while it's open? Wouldn't be able to reach the PTO brake from there and freshen it up would I?
The old girl has been costing me a little lately, but for a $14,000 tractor that we bought to use for backup 5 years ago, it's held up remarkably well for the full time use it gets.
figured getting this brake job done before it turned into a trans rebuild would be a good plan. I'd like to milk this 14,000 hour trans out as far as I can. lol
Thanks All!
Thanks All!
