40 standard vibration
wdan
New User
The high pressure line on my 40s is vibrating after first starting the engine. After the engine warms the vibrating stops. Any thoughts as to what the problem could be.
What weight oil are you using and how cold is it. Probably just heavy oil causing vibration. Do you have oil up to proper level? I don'tthink it is anything to be concerned with
Cold oil. Once upon a time there were vibration dampening straps on there to stop it. Should be one near the front end of the engine and another at the bottom of the dash as well as two for each line on the backside of the dash.
