miraclefarms
New User
I have a 1974 model John Deere 4430 tractor in which I just
replaced the load control shaft, bushings and seals. At the same
time, I put a seal kit in both scv's. Before the work I did, 3 point
lift worked fine. After the work, no leaks and lift worked great.
Took it home and went to pick up a roll of hay and it would
barely clear the ground. Pulled out of the roll and it picks the
fork up fine. Adjusted the draft lever back and forth but it will
not pick a roll of hay up over a foot off the ground. Have I done
something wrong or do I need to adjust something? Thank you!
