stearing problem on my John Deere 4630
JDHarris
New User
The front tires automaticly turn all the way to the right when tractor is running . Any suggestions would be appreciated
There is a serial number break and two entirely different steering systems.
Time to go find the serial number and post it.
I assume yours is the early style valve. I'd say that something is either worn in the valve internally or it requires some adjusment.
Had a 4020 do the same thing. Would turn hard left once started and other times it would suddenly turn left without warning. Talk about scary on the road at high speed.
I had our 4440 do the same thing, that would be the same steering system as a later 4630. Ended up being an oring in the steering spool valve.
