1941 B oil slinger and cover
MAF
I need to know on the L.H. crank side the oil slinger and cover is there a seal there as well cant remember taking one out and dont see one on J.D. parts list.
PC0330.pdf
Part 1 is the cork oil seal although it's not called that, part 2 is the oil slinger although it's also not called that even though it's mentioned in the title of the page. You may have combo part (2) AB 4463 R which subs for the two part unit of 1 and 2. It is supposed to extend thru part 4 and engage a key in the flywheel to drive the oil slinger, be sure it's lined up to the flywheel mounted on the correct crank spline before any sealant applied to the 'packing' (cork oil seal) dries and will no longer turn on the crankshaft to engage the flywheel key.
