Inner Wheel Weight for John Deere 4650
deere70
I didn't know if any one had tried this before. I am needing the 1500lbs wheel weights for our 4650. I have not been able to find a pair for it. A friend has a set of 1400lbs weight for an 8400. In the parts book the numbers are different. The part number for the 4650 is R72266 and it is a 1500lbs weight. The part number for an 8400 is R152116, which is a 1400lb weight. I didn't know if the numbers didn't cross because they are a different size weight or the dish of the wheel hub was enough different it wouldn't work. Thanks for the help.
Could very well be the shape of the weight doesn't match the wheel. I had to machine some spacers to get some outside wheel weights to fit the inside of the wheels on my 4650.
