G pumping oil out breather
Possible breather plugged, oil level over filled, internal engine problems, and etc. Need more information on how it runs and etc.
Are you talking about the engine air breather or the vent in the governor? If it is the vent in the governor, you probable have a drain plugged.
If you take the fill plug off with it running, is there a lot of blow bye coming out the fill hole? Is so, then the rings, pistons, or cylinder walls are bad. It is building up pressure in the crankcase.
