4040 cab window seal
I recently had my 4040 painted,got a cab kit with window seals.Can not find seals for the little door by the brake peddles,and the hinge side of the big door.The dealer say no longer available. I am shure somebody on here knows of a sourse.Thank you in advance.Lloyd
4040 parts catalog states to cut from RE15998 Weatherstrip - SEAL, DOOR FRAME ADD 55.92 USD
Don't you just hate bad dealers !
I used to have people calling me all the time wanting used parts for 2 cyl. because the dealer had no clue and told them new it was NLA. I'd give them the part number I ordered for my stock !
Keep in mind that with the JD weatherestrip, you have to glue it in place with adhesive. Which can be a pain trying to hold it in place. I know because I went thru it. I thought the pressure of the door holding it tight would glue it really good but it peeled right off. I found some peel and stick from some other companies and it was much easier to work with.
