730 hydraulic pump question
09sdfarmboy
New User
Hydraulic oil started going into my crankcase on 730 gas. Has to be coming from the seals in the pump. Does seem like the shaft is wore by the seal area. Gonna get shaft spray welded. my question is you can't get a double lip seal anymore, requires two separate seals, Do they get installed with lips opposite or one to the pump and one to the gear housing. Thanks for any help
