Stockman43
New User
I have a john deere 6300. The tractor stopped running in the field. John deere replaced a spark plug looking device that screwed into the injector pump and it started right up. Next time i started after two weeks, the tractor would start and only idle until it warmed up 10 or 15 mins, then it ran normal. After another week, the tractor was hard to get started. Replaced the fuel filter, but this didn't help. The fuel pump is pumping normal and has about 2 psi. Checked all fuel lines and they are dry with no leaks. The fuel pumps continues to run and i was thinking it used to shut off after turning the key on and it built pressure, but now it runs all the time with key on and tractor not running. Any help would be appreciated. Thanks
